I tried powering on my VHT Lead 40 a few weeks ago and after about 2 minutes of power, it went dead. No indicator lights are on, and the preamp tubes aren't glowing, but the power tubes are glowing. I have replaced all fuses inside the chassis as well as the power supply caps, and a few other caps that looked bad. Checked all solder joints and all seemed fine. Still no luck. Not sure where else to check for problems. I would appreciate any advice you all might have here.
Thanks
Thanks
