Repairing one of these for the same person with a dozen other SS Sunn amps I've fixed the past couple weeks,
This one had a noisy preamp, all channels loud white noise.
It seemed to be those funky 7933 opamps. Luckily I had a bunch from another dead Sunn PA, swapped out the first three and it was much better.
While probing around I accidentally killed the +15v preamp Zener.
Swapped in another, amp back up, then I realized the -15v supply was only like -6v! Replaced the other Zener and HEY! Preamp is super quiet, no while noise at all!
Always check the power supply idiot! (Talking to myself) The other 7933's are probably okay, well one had a dead half.
Output drivers are running a bit hot, I'll probably swap in some newer beefier ones. Concert PA (1).pdf
