Hi all,
I have an intermittent fault with a Vox VT50 whereby the digital PCB doesn't initialise, although sometimes it does . Sometimes it will drop out when it's working and powering it off and on again causes the power cycling problem to return.
The +-15 and +-34 rails appear to work fine, no signs of sagging/changes during malfunction. The 2.5 and 3.3v rails for the digital board are fed by the DC6.3v supply, measuring the voltage on the connector CN12 pin 8 I can see 7.9v, when the failure mode happens it drops to 6.3v. Occasionally when it's powered up and working a hum/buzz will start rising up and the observed reading on that pin drops down to around 6.5v, often restarting the unit keeps it stuck in this looping startup mode.
Is this likely to be a problem on the digital PCB voltage regulator pulling too much current causing the sagging? If I remove the 12AX7 which shares the circuit the voltage never sags and the digital board always initialises. As far as I can see the "6.3v" rail carries the heater for V2, the fan and the 2.5/3.3v supply, so one of these must be at fault.
Any advice gladly taken
Thanks.
Thanks.
