Vox Pathfinder 15R head hum - not output
  • Vox Pathfinder 15R head hum - not output
    There is a constant hum, volume control does not effect it. Looking at the schematic and PCB - VR4 is the master volume and since that does nothing it's gotta be after it. Looking at IC4. I tested the voltages and they are as follows:
    Pins:
    1: 0v
    2: -2v
    3: -20v
    4: -2.3v
    5: 20v
    This seem correct?
    Click image for larger version  Name:	full?d=1349532940.jpg Views:	3 Size:	146.3 KB ID:	910903
    Real TDA2030 are hard to find, but LM1875 fits, I'd try one.
      Pin 4 of IC 4 must be around zero.
      Try and avoid fleabay!
      Support for Fender, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
        When attempting to diagnose a fault on these 'all in one' output ic's I find it best to look at the input signal going to the IC..
        If the power rails are good & the input is good but you have a bad output, it is highly probable that the output IC is bad.
          Temporarily disconnect the reverb at W4.
          Improvised solder on W4 connector, cable with 6.3 mm female guitar jack.
          Connect the guitar to the 6.3 mm jack.
          Set the VR4 on 5 to 8, and VR7 to max.
          If you hear a clear and loud guitar tone the IC4 (TDA2030) is correct.
          Who does not know and knows that he does not know - teach him Confucius)
          Who knows and does not know that he knows - wake him Confucius)
          antalya escort
          kartal escort
          sex vidio
          altyaz?l? porno
          antalya escort
