I have a Black Cat 30R (Matchless DC30 clone) from Bad Cat here with low B+, it should be about 350V but is in fact around 310V. There is about 14V AC ripple. The power transformer is providing about 560VAC which lines up with measurements I took last year when there was no issue with the B+. The amp has a 5AR4 tube rectifier as well as 2 different diodes for rectification. The 5AR4 tests OK on my tube tester and I also popped in a brand new 5AR4 just to be sure. One diode is labeled D420C and measures 0.490 forward voltage. The other is labeled GI828 and measures 0.360 forward voltage. I have not located a datasheet for the D420C, but the datasheet for the GI828 indicates forward voltage of 1.05 so I'm wondering if that could be the problem. The filter caps all test good. I have 6A6 diodes in stock rated at 600V and I am wondering if that would be a suitable replacement for one or both of the existing rectifier diodes. Thoughts anyone?
Edit: I should add it has choke as well. Here's a schematic for the Matchless amp.
