Bad Cat Black Cat 30R Low B+
  • #61
    What about the pin2 grid voltages?
    • #62
      They all show roughly the same, initially they were around 6.7V but appeared to be steadily increasing so when I shut it off after two minutes or so it had climbed to around 7.3V.
      • #63
        There is no salvation from the horror.
        Let someone to try draw right schematic.
        It's All Over Now
        • #64
          Should be 0V on cathode bias, right? Coupling cap? I'll look into it.
          • #65
            I'll throw you a bone. This is what I've completed so far.
            • #66
              There's a mistake in the LTP. The cathode bias resistor is on the wrong side of the 2 x 1M grid leak resistors
              • #67
                Good catch! Here it is revised.
                Generally speaking, this is obviously still very much a work in progress.
                • #68
                  With your permission a little help to a friend.
                  If it's easier for you, look at the layout
                  https://music-electronics-forum.com/filedata/fetch?id=911249
                  It's All Over Now
                  • #69
                    That may come in handy, thank you.
                    • vintagekiki
                      vintagekiki commented
                      Editing a comment
                      I'm here to help
                  • #70
                    PI master grid and slave triode grid is still confused
Name:	Still confused.jpg
                    • #71
                      Matchless dc30 pwr
                      http://www.prowessamplifiers.com/schematics/post/matchless_dc30.pdf
                      It's All Over Now
                      • #72
                        And its clearly still wrong ...
                        The tail resistor should be grounded (or ground referenced to an NFB loop). Instead the LTP cathode is grounded (the way its drawn in the OP's schematic)
                        • #73
                          Ok, now we're getting closer.
                          So we have unwanted positive grid voltages. There's no doubt that this causes the high cathode currents and low B+.
                          Please proceed as follows:
                          1) Measure socket pin 2 voltages with all EL84s pulled.
                          2) Make sure that the junction of the two 220k grid leaks is well grounded (0VDC).
                          3) Lift both 47nF coupling caps and remeasure socket pin 2 voltages.
                          • #74
                            Schematics Matchless dc30 pwr is correct.
                            Compare
                            http://dealers.korgusa.com/svcfiles/ac30p1.pdf
                            DC30 and AC30 do not have NFB
                            It's All Over Now
                            • #75
                              I think the 100k is the tail resistor and is grounded together with the upper PI input (assuming there is no NFB).
                              (Using a continuity tester and/or Ohmmeter can be a big help in finding hidden connections.)
