Here I am Sunday morning, back at the shop at CenterStaging,LLC's main building, where they relocated all of the administration offices, all of the Rental Inventory (apart from the Pro Audio Dept), and the beginning of July, relocated me to set up a temporary shop. So, I've been here since July, and, as the building is air conditioned, its' a WHOLE LOT COOLER than hanging out in the apartment 5 miles away in Glendale, where its' 97 deg F outside, and over 80 deg inside. All the rental apartments you find in the San Fernando Valley, Burbank, Glendale and the surrounding areas have those wall-mounted air conditioning units. Worthless and EXPENSIVE to turn on. Even trying to use them as a fan is a waste of time and energy. All I have at home are two ceiling fans...one over my desk in the front of the Apt, and one over my bed in the bedroom. I salvaged one of those high velocity squirrel cage fans used on stage that we rent and brought that home, after the last Patton High Velocity Cooling Fan failed. Sure wish they continued to make them. I've yet to find one that lasts as long as those Patton Fans did.
So, while waiting for Gallien-Krueger to send the replacement cast aluminum front panels for their Fusion 550 Bass Amp (and other parts needed to restore the four we have here in the shop), and maybe finding the problems in a couple Line 6 Guitar Amp heads that are in the Repair Pile out on the Warehouse Staging Area's zones, I've just run out of work. The Diecast aluminum front panels for the Fusion 550 amps have the rack mount holes placed at the upper/lower corners of the 3U high rack panel, rather than 1-3/8" down from top/bottom of the panels where we normally see them. The rack mount holes are breaking off when mounted in road cases. Only one of the four Fusion 550's we have in our rental inventory hasn't suffered this damage. I can imagine the conversations in their engineering dept from this oversight on the product.
I had an SWR Goliath III 410 Bass Cabinet in here with a gaffers tape label stating 'Blown Spkrs'. Checked it out yesterday, and after removing the front metal grille, finding some of the rubber feet that are used to prevent the grille from bending in, allowing the cone excursion to slam into the back side of the grille, the four cones were in fine shape. Common ailment I've found on SWR, Aguilar, Eden, GK and many other 410 cabinets with light spkr cones, accordion-pleat surrounds, when pushed over time, the cones themselves begin creating a new radial crease just inside the area where the cone joins the surround suspension. These four speakers didn't have that, and, usually when it's gross, I hear it every time I excite the cabinet with LF 1/3 Oct Pink Noise or Sine-Random noise, tuned in the 15Hz-40Hz region. I wasn't hearing that this time, but, after I fetched a GK 1001RB Bass Amp to plug the Fender Jazz Bass into and drive the cabinet (grille still removed), hammering on the low E string, the left pair of woofers were barking loudly, though fine at moderate levels. Yup. Blown, without visual clues.
I haven't been the one who's been ordering the replacement speakers on all of the bass cabinets I've serviced since last November, when I began doing Preventative Maintenance work on the rental inventory. Since Fender bought SWR, and stopped production on all of the SWR amps, I assume the same can be said on their speaker cabinets. I thought I had opened up one of the SWR 410 cabinets, but in checking my database, I had only serviced two of their 410 cabinets, and three of their 810 cabinets, while NOT removing any woofers to get details on the spkr mfgr/model number. I guess I'll have to do that this coming week. Though not much chance in getting expensive replacement parts ordered while there's so little income coming in. I do see equipment going out to clients, but nothing like it had been prior to the Pandemic.
Thus far, all my labor hours have been applied to covering my shop space use...I trade 20 hrs a month labor for shop space, after which I hit billable hours. But, with the Pandemic in full swing, with our entertainment industry still at a standstill, there aren't likely to be any billable hours. Still waiting to hear if I'm liable for April, May & June's shop space while the company has been shut down. I've covered March and July, and nearly thru with covering August hours. CenterStaging had rented out the building (to a steady client) where my normal shop is located, and as such, I'm not allowed in the building without special permission. That hasn't yet become a major problem, having moved essential gear, tools and supplies needed over to the main building where I am now.
So, I guess I'll resume Preventative Maintenance work, and rack up more hours to cover shop space. Having survived thus far on the UPA benefits, which just ran out of the Federal funds the end of last month, now it gets interesting from a survival standpoint. While we're now in the dog days of summer, hottest we've seen this year so far, I'm thankful I can come in to just get out of the heat and hang out at the shop. There's always something to do here, even though there's no income. My Yamaha P2100 power amp that I had restored last November to use in the Loudspeaker Test Station I set up, now the Ch A has crapped out (it was Ch B that didn't work when I inherited it a few years ago). So, I'll pull it apart this week. If I can get into my shop down the street, I have to bring over my HP 6227B Dual Tracking Power Supply, which had one channel fail recently, so there's another project.
So, onward until they close up around 5PM today. Then, I gotta go endure the heat, which of late, is still in the mid-80's at 11PM out here in Burbank/Glendale.
