That’s fair enough, Helmholtz. Sorry!
C15 58.4 V wrt ground on +ve terminal
C25 -58.0 wrt ground on -ve terminal
although readings fluctuated up to a volt.
I noticed that when I lifted the board up vertically to access the underside the hum git worse significantly as the board approached vertical. This was with board earthed with flyleads btw.
To be fair, the hum is better than it was! Definitely an octave below the transformer hum by the way (it would improve things if I could do something about that!).
Appreciate your help!
