Originally posted by Rhod
View Post
Hum/buzz on Trace Elliot Commando - not filter caps!
It's All Over Now
As shorting pins 1 and 2 disables the vol pot and corresponds to zero vol setting, there is no indication of the pot being the culprit.
C21 and C28 present the coupling between signal and chassis grounds. Both capacitors, if measured with an Ohm meter should show infinite resistance (range 200k or more) and if your multi meter has a capacity meter the capacity should be 100n +/- 10% The voltage at both points is 0V dc
No capacity meter sadly.
Can you do a couple of things for me? With the volume at zero report the ACV across the speaker terminals. The other is can you post a clear picture of the guts?
Ta!Experience is something you get, just after you really needed it.
Apologies for radio silence...
Vintagekiki:
C21 and C28 both measure 10k ohms or thereabouts in circuit - so lower than suggested.
Helmholtz: Have tried aluminium foil-on-cardboard connected to chassis, place.. Doesn't affect the hum (I wondered if it would, as the hum gets worse as the circuit board is lifted to the vertical, and I've also tried turning off nearby fluorescent lights and transformers with no change)
nickb - hello! - AC voltage at speaker terminals = 0.3v BUT while I was there I also measured the DC offset, which I hadn't done before, and it was 0.4v, which sounds high to me....and when I went back to check the AC again it measured 0v (speaker out of circuit btw). Picture coming up...
Thanks, folks.Last edited by Rhod; 09-07-2020, 06:26 PM.
Thanks for the pic and the speaker AC info. I could not recall if this model had a separate preamp with a long wire going to the power amp. They can be a source of hum. This is an all-in-one so it's not that.
If you are measuring 0VAC hum then the hum would be quite low level. I'm suspicious that you might be trying to improve on the original design . Do you have a mV AC range? If you do, try that. BTW it sounds like your meter might be an inexpensive one that doesn't do RMS nor blocka the DC. When you measure add a 100nF in series with the meter lead. Also if you see 0.4V DC again that is on the high side.Last edited by nickb; 09-07-2020, 09:23 PM.Experience is something you get, just after you really needed it.
If you are measuring 0VAC hum they the hum would be quite low level. I'm suspicious that you might be trying to improve on the original design
No mV AC setting, I'm afraid - if nothing else through this thread I've learnt about the limitations of my meter...
Measured 0.7V DC on the speaker terminals when switched on, but this gradually reduces. After about 5 mins it goes down to between 6-20 mV (constantly changing).
Has anyone had any experience of repairing noisy transformers like this guy?
https://www.youtube.com/watch?v=dtOwewfqucI
The quickest way to determine where hum/buzz comes from is to connect the amplifier to an external speaker.
The transistor amplifier is free to power on without a speaker. If hum / buzz is still heard without the speaker from the amplifier, there are 2 causes.
Either the transformer is not evenly tightened to the chassis, or the hum/buzz originates from the transformer because the sheets inside the transformer are not tightened to each other. The solution is to "drown" the transformer with a special varnish.
It's All Over Now
(Tried to post over the last couple of days but unable to connect to the website - don't know if that was a more widespread problem! Anyway, we're now back in the room!)
Thanks, vintagekiki. I'd established that I had both issues: 100hz buzz from the transformer AND 50Hz at the speaker. Both were annoying: this thread has focussed on the speaker hum but I have news on the transformer!
Well noticed regarding R30 and R31 - this area has been repaired in the past and their positions on the board have been reversed (i.e. R30 is next to the printed label on the PCB for R31 and vice versa - not sure why). Having checked the circuit, I'm pretty sure that they are wired up correctly, however.
So I'm still left with the speaker hum, and maybe nickb is right and I'm chasing something unobtainable. I do think it's worse than it should be, though, and I haven't completely given up!
BUT I was looking at the transformer and considering a repair as above.The transformer is riveted to the chassis, on a rubber mat, and all seemed solid (and not easy to remove as I would have to drill it out if I was thinking of glueing the laminations). I had previously tightened up two bolts running through the core (top and bottom) and noticed 4 "spare" holes at the corners. I happened to have some bolts of the right size with wing nuts that lodged into the corners (difficult to get a spanner or socket in between the chassis) and tightened them up. Bingo! Transformer buzz almost disappeared! I can hardly hear it running now...until I connect the speaker of course... I wonder if it was meant to ship with those bolts installed. Anyway, this is progress.Last edited by Rhod; 09-10-2020, 09:21 PM.
- Likes 1
Yes - although it’s not super quiet - it’s an old amp after all, it reduced the noise to an acceptable level for gigging although I’m not sure I’d record with it. Tbh I tend to record bass straight into the desk anyway!
Although I was miffed at replacing all those caps in the quest for a quieter amp I was happy to get something eventually that was usable. And I like the sound of those amps. They’re dirt cheap but sound really nice to my ears!
Apologies for not picking up your message before now. How’s your Trace sounding?!
