Hi all,
I've just resoldered a loose input jack on my Marshall VS100R and had to remove and reattach the PCBs to do it. A new problem popped up afterwards and I'm at a loss about what the cause is.
The problem is that while the amp sounds good with the reverb knobs turned down, but with them turned up I get a noisy, crackling sound, even with no instrument cable attached. Also, it smells like a component is overheating after ~15 seconds of power-on - regardless of the reverb knobs settings - so I don't want to plug it in for more than a few seconds to get voltage/current measurements for the repair work.
I'm really hoping this'll be a quick one for you amp gurus out there. Any ideas on what I can do or where to look (I've got a show next weekend and our tones are dialed in for this amp)? I found a link to the schematic if it'll help.
http://www.drtube.com/schematics/mar...v100-60-02.pdf
This may be a clue - I've noticed that the resistors R21 and R20 (180ohms @ 3W) in the voltage regulator circuit are dissipating over their wattage range (between 4-5W) since I measure 30V and -28V DC dropped over them, respectively. I'm thinking there's a problem with the caps in the regulator circuit keeping them from charging to 100% of the supply voltage. Possibly there's a problem with the regulators themselves, but I'm very rusty on my electronics know-how. I would love to get a second opinion before I pull out the PCBs again.
The schematic has R21 and R20 on the bottom right of page 2.
http://www.drtube.com/schematics/mar...v100-60-02.pdf (same PDF)
I've found that PSU+VE is +40V DC and PSU-VE is -40V DC so I'm really starting to think that the capacitors C9,C10,C11,C12 and possibly the voltage regulators REG1 and REG2 need replacement. Does this jive? See anything I'm missing?
Thanks very much in advance,
Shaun
Shaun
