Google brought me to the very enlightening thread between W2L, Enzo and others on this forum concerning an Acoustic 320 with low gain in the power amp (first hit on "acoustic 320 low gain"!).
My first hope that my own low-gain-320 could have aquired the same disease was however disappointed. The AGC (the limiter circuit) does not seem to be the culprit - I tried to remove the jfets Q1 and Q2, and output is still low. As Enzo has convinced me, this proves that the AGC is not involved.
Unfortunately I don't own an oscilloscope, only a multimeter. But my ears tell me that the amp doesn't distort, it just plays low. I tried feeding the power amp directly with my SansAmp D.I. - still low.
There is one other thing that perhaps could be a clou: The Acoustic has a "Power Boost" button that used to make the amp play even loader (but less "hifi"). But now it just cuts a little off of the treble, the gain is unaffected. When I look at the schematic, turning power boost on, grounds C3 and R15. Grounding C3 must create a low pass filter on the input, right? This corresponds to what I hear. Perhaps that could indicate that the power button only has effect on C3 but on in the R15 area (btw, I checked R15 and it matches its color code)...
Test points: There are some test points on the scematic.
between C6 and R10: Expected 21v, meassured 20.6v
between Q4 and R19: Can't meassure, the amp oscillates if I touch here (ouch!)
between R5 and R43: Expected 10v, meassured 6.3V
supply: Expected 93v?, meassured 93v
output line, left of inductor: Expected 42v?, meassured 44.6v
base of Q11: Expected 1.45???, meassured 1.5v
The schematic I found on the internet is barely readable, thats why some of the values have question marks. I anyone can point me to a readable version, I would be grateful.
I'm pretty stuck at this point, any suggestions on how to move forward is appreciated! I already got one suggestion from the back of the amp: "Refer servicing to qualified service personnel", so no need to repeat that
Jeppe
![Wink](https://music-electronics-forum.com/core/images/smilies/wink.png)
Jeppe
