Hello !
The case is, I have a jcm 900 4100 head with Red Plated in all the power tubes. This is the history about what happened with my main amp ( this jcm 900 head 4100).
In a rehearsal with my band, 10 months ago something happened with electricity, maybe a surge and it damaged some devices in the house. I was playing when this happened and 20-30 seconds after the incident, the main fuse in the jcm 900 was blown ( 4amp) replaced twice and always blew the fuse.I made some measures in the power tranny and it does not deliver the right voltaje. So, I ordered a new power transformer for classictone and after 6 months it arrived to my country ( this took a long time because some friend did the favor to carry this to my country by sea)
Last weekend I had the time to change the transformer and voila! It does not blow fuse , but the sound is good for 10 minutes and after that all the power tubes went to red plating and the sound goes down and shows some grid or little distortion in the trail of a sound , for example, if you play a chord , it vanishes with some distortion, only when is red plated. I played with the old 5881 and red plated like hell but after half out of the test, the tubes fuses 500ma were blown! Before it I checked the voltage in the union of r27-r26, according to the schematic, it must be -50 volts but I always obtain milliVolts dc readings.
Yesterday I replaced the tubes with 6l6 and new fuses and it sounded but after 4 minutes the same behavior! Diminishing volume, all 4 tubes red plated and grainy trail in sound and check bias voltage and my dmm only show - 30 milliVolts dc. approx. I checked my Digital Multimeter and it seems to be ok.
Do you have any suggestions to fix my amp? I need some directions or advice because I don’t know what’s next to do!
I have some electronics skills because I used to work with electronics when I was in the university, but after that I studied Computer Science, Right now I am unemployed![](https://music-electronics-forum.com/core/image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. I really want to have local tube amp technicians here in my county but there`s nobody here with education or demostrated skill reapairing tubes amp, so I always service my amps, little things like change broken components, some basic tests, biasing, change tubes. Im guess I have fundamental knowledge, so I know some little things but I am not an expert.
Attached you will find some pictures and schematics and specs from power transformer, and JCM 900 4100 head
Please Help me!
Please Help me!
