I'm working on this cool mid 60's Ampeg with a 15" speaker which sounds pretty good but the tremolo isn't working. Is the brass wrapped axial wired component an optoisolater? If so how can I test to see whether it's working and more importantly what is the replacement if it's not?
Ampeg Gemini G15 No Tremolo
You can see that one end of the tube is bayonet based light bulb and there probably is a photo cell on the other end. If you look at the schematic for the amp, you might be able to tell what kind of bulb is in there and how it is wired. A lot of Ampegs used neon lamps in the trem circuit, but I suppose that they could have used an incandescent lamp in some of the amps as well.
If the bulb is filament based, you should be able to read a resistance across the filament terminals. If it is a neon lamp, there will not be a resistance across the terminals.
Schematic?
Sticking out one end of your cylinder, don't you recognize the base of a light bulb? Brass, and has the little peg sticking out for the bayonette base holder. It might even be home made, I personally do not recognize it as a commercial unit, though it might be.
I found a Joe Piazza drawing, always hard to trust, and it shows a neon and photocell opto like a Fender roach. NE-51 maybe?
It is a neon lamp, and a photocell, each being independent electrically. But we are getting ahead of ourselves, we have decided to worry about the opto before we have any idea what the issue might be. A loss of trem can be due to anything from the trem tube not oscillating to an open resistor to a bad lamp in the bug, or a bad photocell in the bug or wiring to the signal path or a problem with the depth pot. The trem tube could be bad, could be not lighting due to missing heater current, to a bad stomp switch to turn on the trem, or faulty/leaky caps around the tube.
So we find out what is happening. Is there a large trem signal at the plate of the tube? Is the tube heater on? Is it getting B+? From the plate is a 390k resistor down to the lamp, other side of lamp to ground, so if we have trem at the tube, do we also still have it at the lamp? Turn off the room lighting, and see if you can see any evidence the bulb is flashing inside that cylinder.Education is what you're left with after you have forgotten what you have learned.
- Likes 1
Here is a factory schematic for the 7591 version of the G-15 Gemini II.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Originally posted by drewl View PostMost of the time the caps in the oscillator become leaky.
- Likes 1
Check that the neon bulb (TM1) lights up in the rhythm of the oscillator frequency.
If the neon bulb lights in the rhythm of the oscillator frequency, check whether the resistance of the photo-resistor (point x y) changes in the rhythm the neon bulb.
Before replacing any passive components of the tremolo oscillator, replace the existing tremolo oscillator V7 tube with a new one (not like a new one), and measure all operating voltages. You know the rest ...It's All Over Now
Last edited by tubeswell; 09-07-2020, 09:00 PM.Building a better world (one tube amp at a time)
- Likes 3
Does it sound like the module is not working and if so, can I use a standard Fender optocoupler to replace the entire TM-1? The bulb doesn't want to come out easily which makes me believe that this was sealed unit. I found a company fliptops.net that sells a replacement TM-1 but it's $40, lol.Last edited by Perkinsman; 09-08-2020, 12:37 AM.
- Likes 1
