I know from experience that if you ground the neg. terminal of a bridged conventional amp, you will only measure half the power. Why nothing gets damaged escapes me at the moment, but again, from experience I know I've never damaged anything by doing so. I suppose the ground is lifted in bridged mode?
But I've come across some suggestions that it will cause damage to a Class D amp that has floating outputs. I seem to recall a Fender service manual for a Class D amp specifically cautioning against grounding the neg. output terminal?
Is it correct that a Class D out should not be connected to grounded jacks? If so, is it all Class D, or only some?
