Q1 on this Fender Scorpio schematic (early solid state) says F1175. The transistor itself reads 908W38 (the 9 might be a lower case g). I can't find any info on it or cross references. I'd like to replace it, normal channel is low output, this transistor has +15vdc on all legs. Thanks for your help
Need help ID'ing this transistor
Try a J112 Jug Fet.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by acorkos View PostQ1 on this Fender Scorpio schematic (early solid state) says F1175. The transistor itself reads 908W38 (the 9 might be a lower case g). I can't find any info on it or cross references. I'd like to replace it, normal channel is low output, this transistor has +15vdc on all legs. Thanks for your helpJuan Manuel Fahey
- Likes 1
Originally posted by Helmholtz View Post2N7000 is a Mosfet. Schematic shows an N-channel Jfet. Looks like a source follower (buffer) stage. Please post full schematic.
fender_scorpio_sch.pdf
Okay cool. I’ve only worked on an old Fender Taurus model Zodiac amp. It has that same input jfet and it is connected to the board through a plastic mounting bracket (for lack of a better name). I was looking at old Motorola jfets from that time period that had 4 legs.When the going gets weird... The weird turn pro!
Originally posted by DrGonz78 View PostOkay cool. I’ve only worked on an old Fender Taurus model Zodiac amp. It has that same input jfet and it is connected to the board through a plastic mounting bracket (for lack of a better name). I was looking at old Motorola jfets from that time period that had 4 legs.
1 Photo
The plastic spreaders were used as insertion aid and to ensure a minimum lead length to prevent excessive chip temperatures when soldering. They also prevent sharp lead bendings right at the component.
So I assume there should have been 2 of them.- Own Opinions Only -
Itīs a simple JFET unity gain source follower.
Its job is easy so in that case, "any FET" will work, including J112 suggested by Jon Snell.
Just take care of pinout, apparently G-D-S are silkscreened on the PCB
Your symptoms might show a shorted FET *or* open R9
Turn ampOFF, wait for supply voltages to reach 0V (to drain the last drops ground +V through 100 ohm 1W or similar) and measure resistance from Q1 source to ground.
Measure from Fet leg itself to ground.
You should read 47k , within tolerance.
IF you jhave properv resistance value, then dead FET is confirmed but itīs easy to substitute.
Good luck.Juan Manuel Fahey
Originally posted by acorkos View PostQ1 on this Fender Scorpio schematic ... normal channel is low output, this transistor has +15vdc on all legs
Eventually you can reciprocally swap places Q1 and Q2 to determine the correct state Q1.
It's All Over Now
