Hi, all hope you can help, I have a faulty Roland cube 40xl amp it has no output when I switch on all the led lights come on most times!
I don't have a schematic can't find one but found the same model transformer which says it has 2x 15v ac out and 0v on output it measured ok on the 3 pin multiplug which connects to the mainboard so taking the transformer as good I'm guessing the amp is in a mute or protect mode what would you advise next?.
Also when all LEDs all lit up if I power off switch then back on one light goes out rest still on if I repeat it puts another light out even changing colours on one1 all in order left to right like an engineer test mode hence my thinking it's in mute protect mode.
I read a post were someone said they disconnected the 4pin multiplug centre of the board while powered on then replugged in while still powered on! and it reset a chip and amp came back on normally a bit like a stale laptop bios Cmos reset any help much appreciated or a schematic I have one for the cube 80xl but no idea if they're anywhere near the same!.
