Originally posted by bobloblaws
View Post
Home Stereo Amplifier Overload Indicator
Originally posted by The Dude View Post
If measurements are correct, either the transistor is bad (leaky/shorted) or it's installed wrong (basing diagram). With only -.023 B-E, the transistor should be off and collector should be at 0VDC.
One thing I don't think has been tried. When the LED is on, short out R005. Does the LED then go off?
And which part is currently installed for Q003?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Originally posted by g1 View PostAnd which part is currently installed for Q003?
Originally posted by g1 View PostOne thing I don't think has been tried. When the LED is on, short out R005. Does the LED then go off?
Well, success to some degree at least. The LED is staying off now after replacing R005, R004, D007 and D204 (they had all been snipped at some point) and soldering Q003 back in. The right channel overload indicator lights up briefly sometimes when first powering the amp on, maybe after it has been off for awhile? Also, if I shift R243 (R143 on the drawing) in either right or left direction with my chopstick the voltage on D204 anode drops about half of a volt and the LED lights up. The same does not happen on the left channel. I took the board back out (for the umpteenth time) and re-soldered R204 and a couple of nearby solder joints as well. Still does the same thing. I'm prepared to leave well enough alone at this point. However, there is another oddity. When I turn up either channel to the point of overload, both overload LED light up. This amp sure has some pesky gremlins hiding in it!
