Friedman Runt 50 watt head with fx loop issue
  • Friedman Runt 50 watt head with fx loop issue
    Good morning too you
    I have been asked by a local guitar shop for my views on this issue
    One of the staff members bought a Friedman Runt used. Found by using the amp worked perfectly and sounds great
    when using the send and return there is a background noise ( ground issue to my basic ears ). The pedal board was looked and and the manager of the shop rebuilt it with new cables and new pedal power psu. The manager has 26 yrs shop experience and builds pedal boards always weekly,., checked all the leads and lead address, positions of psu and pedals, psu output voltages etc, Even breaking a ground somewhere to see if that cures anything This is happening in the shop/studio/home,
    Pedalpower 2
    strymon -el capistan
    eh - micro pog
    mxr -acid fuzz
    jhs - sweet tea
    Wah wah
    all of these pedals were no issue with previous amp marshall head
    With the pedal board plugged into a JVM 50 watt combo its good no issues
    The manager took home the pedal board and tried it in his own amp Friedman brown eye no issues
    The manager put his own pedal board that has no issues in the brown eye into the grunt, it was noisy
    I had a quick look inside the amp. Solid state send and return, no viable issues seen
    The amp owner has contacted David Friedman many times and he denies any issues with the fx loop
    Both guys have searched the net and it apparently seems to be an issue with noisy fx loops
    My question has anyone had this problem and found a cure
    one of a few posts on the net
    https://www.thefretboard.co.uk/discu...-friedman-runt
    https://www.rig-talk.com/forum/viewt...?f=57&t=185597
    https://www.thegearpage.net/board/in...noise.1805047/
    I have to say i have not read these posts above
    many thanks
    A
    Will you read our answers then?
    1) do the most basic test with the simplest effects chain: plug a short cable fron send to return.
    repeat with a long one. Any change?
    2) test with a simple pedal, **battery powered** , so itīs fully floating and we remove supplies, outlets and external grounding from the equation.
    Repeat with same pedal but now powered from a wall wart.
    Plug both amp and pedal supply in the same extension so as to avoid "different outlets" blues.
    Repeat plugging each supply (amp and pedal) in its own outlet.
    3) identify noise properly: hum or hiss?
    Because some of the links you did not read speak of hiss more than hum, very different.
    Do all tests and post all results, even if "all are the same".
    If available, post schematic, but at least a nice picture showing effects loop area, PCB both sides, maybe we suggest cutting and rerouting some track or wire BUT we need your data input.
      Ive been told they have found a solution. a little bit of moving about has got the noise acceptable . Again this pedal board as it is through other amps quite, through this runt. its not perfect. but he is happy with it
      I guess you have to play with the layout sometimes for each amp
      I made it clear that i'm not getting involved with the amp for this fault
      many thanks
      Mr A
      This post is now done
        which effects processor would you recommend to be use in the effects loop of this amp?
        Boss GX-100: https://www.amazon.com/Boss-GX-100-G...43&sr=8-1&th=1
        Boss Gt-1000 or Line 6 Helix?
        Easy to program and quality modulation effects.
