I have an odd issue on a Princeton Reverb that I've never dealt with before. There's an unatural sound that occurs more prominently around certain frequencies, mostly around an A chord, which immediately made me suspect that something was loose in the cab. At first I thought it was a loose speaker on the baffle but tightening the nuts didn't help. I looked for other loose joints in the cab or even staples holding the cloth but couldn't find anything loose that might be causing the rattle/buzz/fizz sound. I thought I remember seeing a youtube video once about a similar problem but i can't find it now. Looking under the chassis for loose components didn't yield anything either. Most all of the ecaps have been replaced. Has anyone here experienced a similar problem or have suggestions?
Fizz at Certain Frequency's on Princeton Reverb
Isolate the problem. Disconnect the speaker in the amp and wire it up to some other speaker cab. Does it do it over there?
And a different ttest, remove teh amp chassis, but leave the chassis connected to the speaker in the cab. Does it still do it that way?Education is what you're left with after you have forgotten what you have learned.
- Likes 1
Hi. Ive done a few of these recently and turned out to be the power tubes, Replaced them cure the issue, I would check it with another speaker / cabinet to see if it the speaker as enzo says ,
Just as another point, I have had a fair few set of TAD ( Tube amp doctor) that have had this problem
6V6 and EL84
Mr A
- Likes 2
That's good to know about those tubes, luckily I have my local tube supplier who i know and trust and has good test gear. As far as the noise, isolating the problem as you both suggested was the key lesson to learn here. I could have bet my next paycheck the fizz/rattle noise was a loose part in the cab, my second guess was the possibility that the speaker was loose on the baffle, my third guess was a tube...but all the tubes tested strong. Using my Deluxe head to power the Princeton speaker cab and still having the problem, I knew it was the cab. I switched out the speaker and voila, no more fizz/rattle!
- Likes 1
Glad you solved it. But just to let you know, a rattling or squealing tube will test fine on a tube tester.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
Originally posted by Perkinsman View PostThat's good to know about those tubes, luckily I have my local tube supplier who i know and trust and has good test gear. As far as the noise, isolating the problem as you both suggested was the key lesson to learn here. I could have bet my next paycheck the fizz/rattle noise was a loose part in the cab, my second guess was the possibility that the speaker was loose on the baffle, my third guess was a tube...but all the tubes tested strong. Using my Deluxe head to power the Princeton speaker cab and still having the problem, I knew it was the cab. I switched out the speaker and voila, no more fizz/rattle!
I changed the tubes for another new set, noise went away
