Amp is Mod101. Kit amp that I purchased from someone who built it non-functioning. I have re-soldered every connection, verified all wiring/connections. Amp is now working, all DC voltages match schematic. However 1 problem remains, there is a fairly loud signal passing through when volume is at 0.
With a 100mv sine wave in input, the signal at speaker out is 4V pk-pk.
The leaking signal is not effected by any of the EQ controls. EQ works fine on regular signal once you turn the volume up.
I've verified the volume pot is functioning ok. Checked all grounds multiple times. Tried swapping V1.
I've tried grounding grid and plate of V1 and found that grounding V1a grid, or V1b plate kills the signal. To me this infers that the issue lies between V1a and V1b in the eq circuit, but I've double checked everything and all seems fine. Not sure where to go from here?
Grounding wiper of volume pot does not kill signal
Grounding v1a grid kills signal
Grounding v1b grid does NOT kill signal
Grounding v1a plate does NOT kills giant
Grounding v1b plate does kill signal
