G-dec
  • G-dec
    Hello
    I have a fender G-dec 15 watt amp
    Wanting to change the volumepotmeter
    because it's broken, I think (Cannot turn down volume)
    anybody know if it is a logarithmic or a Linear potmeter ?
    The Schematic says only 10 KOhms
    The Potmeter itself is marked "b 103"
    Any Ideas for a replacement ?
    Appreciate all help
    Frode
    I'm 90% sure "b" means linear.
    -Mike
      I'd agree.
        Hi,
        on this side of the ocean "A" stands for linear, "B" for logarithmic.
        Regards
        Bob
          In that case, I'd just measure the resistance at 50% rotation. If it's 50% of the marked value, then it's linear.
          -Mike
            Yeah.
            that seems fair
            thanks alot
            Frode
              That would be enough only to draw a line between linear and audio, so it' s ok if the indicated taper complies with the standards, but keep in mind there are some pots with weird tapers ( though I' d say this is not your case ) such as semi-logarithmic ( which are linear up to 50% of the taper and then become logarithmic for the rest of the wiper's travel ) or semi exponential, so, IMHO, the best way to state the true pot' s taper is to use a needle ( analog ) Ohmmeter, ( set to the proper scale and connected between one of the outer lugs and the wiper ), mark the shaft with a permanent felt tip pen and take note of resistance variation at different angles ( standard pots have a 270 degrees rotation field ).
              Hope this helps
              Best regards
              Bob
