I've got an old Acoustic 370 Solid State bass amp that has a minor issue with the low-gain channel, which buzzes when used. The 1st channel is fine.
The first issue seems to be the amp ground. Someone put in a 3-prong cord, but the green wire was cut and not connected anywhere. I took out the "death cap" and soldered the AC ground to the chassis where it was connected.
It still has issues with the 2nd channel buzzing. The scope shows a sine wave on (what I believe is) the board ground when the function generator is connected to channel 2, but not with channel 1, which makes me believe that the issue is the grounding scheme.
Both jacks are 3-terminal with two of the lugs tied together and wired to the board ground to form a voltage divider with different resistors in series (10K and 22K).
I'm not sure what to do next.
Could it be an improper connection to the chassis with one of the jacks?
Should put a ground wire from the AC ground to the jacks?
Any suggestions are welcome!
Here's a schematics page
http://acc.homeunix.net/schematics.html
