Peavey Deuce/Mace Phase, no phase
  • Peavey Deuce/Mace Phase, no phase
    Repaired and re-furbished one of the VT series Deuce, but phase doesn't work.
    U13 is switching properly, color pot just changes amplitude of signal
    I have signal through the delay line U7 through U10, but.... no LFO from U11 and U12.
    I know they are both bad as I subbed them into U14's spot and they kill the signal.
    Funny, while probing with scope I accidentally shorted U11 pins 6 & 7 and the signal "phased"
    No sweep, but a phased sound to the note, shorted the pins again with a resistor and the pitch of the "phase" changes.
    Pins 5 & 6 are at -16v rail, when signal was "phased" output pin 6 changed to ~ +3v
    Ooooh! found a couple PV 3080's here at work! Hopefully they work.
    And just to follow up, replaced the two bad chips and we have phase!
      Glad we could help.
        Spiritual guidance!
        And I found the schematic here, so you did help.
        Sometimes it helps to just talk things out.
