Powers up but no sound unless volume all the way & then still only faint. Slight hum that doesn’t fluctuate with volume. Tubes tested strong. Lifted legs on coupling caps & test in spec. Replaced 2 25/30v Ducati with 2 22/50 Panasonic Audio caps. Measured .02uf coupling caps, both in spec. Voltages on PT plates are 365vdc. No other voltages are listed. Anyone with similar Ampeg experiences?
Ampeg-Jet-J12D-Amp-Schematic.pdf
