They are all cathode bypass caps. See the schematic in post #17.
Ampeg Jet 12d- no sound
Originally posted by Jazz P Bass View PostHere is the original schematic:
The best I can do is post a few pics of the torn schematic on the back of the amps back cover.
At the moment, I have sound again but with a bad hum/crackle. Its not the speaker, I ran to another speaker and still get the same. Could it be the OT?? I have 2 25uf caps that need to be installed today.
Originally posted by Perkinsman View PostThe best I can do is post a few pics of the torn schematic on the back of the amps back cover.
Picture 2 clearly shows that the input triode uses pins 5,6,7 as opposed to other schematics. Even some essential circuit voltages can be seen.Last edited by Helmholtz; 11-04-2020, 05:20 PM.- Own Opinions Only -
- Likes 2
Originally posted by Perkinsman View Post..placement of the 2 25uf caps
One of them goes between input tube pin 6 and ground. Do you have a 100µ cap between pin 3 (PI) and ground (as shown in your schemaic)?
If not the other 25µ should go there.Last edited by Helmholtz; 11-04-2020, 06:20 PM.- Own Opinions Only -
- Likes 1
No 100uf on V2pin3. Why would I put a 25uf there if my schematic indicates 100uf? I installed the 100uf & it stopped the hum!
Also, on the schematic, there’s a 20uf cap from pins 5 cathode of the power tubes but on the amp there’s nothing on pin 5 except a common wire between the two. Should I just install a 22uf cap parallel to 140Ohm/10W & call it a day?Last edited by Perkinsman; 11-04-2020, 08:33 PM.
Originally posted by Perkinsman View PostNo 100uf on V2pin3. Why would I put a 25uf there if my schematic indicates 100uf?
But also the tremolo LFO triode has a 25µ cathode cap.Last edited by Helmholtz; 11-04-2020, 09:49 PM.- Own Opinions Only -
- Likes 1
Originally posted by Perkinsman View PostYes, the trem cap is there but I was asking about the common power tubes 25uf cathode cap which wasn’t present. The amps works without it but I installed it across the 140 ohm/10w resistor anyway.
It's kind of a worst case scenario if there is no valid schematic - and someone changed component positions.
Originally posted by Helmholtz View PostIt's kind of a worst case scenario if there is no valid schematic
Curious if the amp is actually marked as J12D or if that was a typo in the thread title.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Originally posted by g1 View PostWell, the sheet glued in there says J12T (6C10/6BK11 & 7591 version). If that's what we had been looking for it's probably available somewhere.
Apart from that I think we meanwhile know most of the circuit.- Own Opinions Only -
- Likes 1
