Hello everyone.
I've built 3 of these kit amps called "Litlle Rebel" from Musikding. So far and I always have the same problem.
The section of the bass potentiometer in the circuit board acts strange. When I turn the pot down to "0", there is a loud hum, like its not grounded, WICH IT IS! I had the exact same problem in the previous two.
Also, when I connect the DC power supply, the humming noise appears very loud, even more when I turn the bass potentiometer. When the amp is using the 9V battery, the noise reduces drastically, but its there in the background. I'll attach a video for you to see what its going on: https://www.youtube.com/watch?v=7n-21zF ... nZditowski
I've tried to do the start point grounding, but nothing, I grounded to the PCB aluminium plate below and to the plate in the control panel and nothing. I built this enclosure of aluminium but NOTHING, absolutely nothing seems to resolve this issue. I've also tried different DC power supplys and NOTHING. I'll attach schemantics and wiring for you to see.
Please, if anyone can help, its driving me crazy not beeing able to fix it. And believe me, I've had checked and re-checked every solder joint, every component, everything is in its right place!
