My '69 B15N is blowing fuses - I have already unsoldered all the wires from it, HV, filament etc. Still, just after powering it on, it blows a fuse. Does it mean that PT is 100% shot?
Ampeg B15N power trasformer failure?
Disconnect the primary wires too, now blows fuses still? It is possible there is a short in the primary side mains wiring. Otherwise, it sounds like a bad tranny, yes.Education is what you're left with after you have forgotten what you have learned.
- Likes 1
B15s eat power transformers. Its really common. If as Enzo says, it still blows fuses with primary disconnected, you have got off lightly. If its teh transformer, you can either bin the whole assembly and buy a complete potted replacement from Fliptops or Mercury Magnetics. If money is tight you can unpot the original and get it rewound and repot it either using epoxy potting compound or the original bitumen. Its a lot of aggravation and to be avoided if possible. I have a small electric oven I use for B15 transformers after an incident with the kitchen cooker led to some domestic disharmony a few years back.
My personal B15N blew its PT years ago. I had it rewound at a shop in Orono, Maine for a reasonable price. Transformer Rewinding Service. Not sure of his current status, but it is good as new and you couldn't tell it had been done.It's weird, because it WAS working fine.....
Originally posted by Ted View PostB15s eat power transformers. Its really common. If as Enzo says, it still blows fuses with primary disconnected, you have got off lightly. If its teh transformer, you can either bin the whole assembly and buy a complete potted replacement from Fliptops or Mercury Magnetics. If money is tight you can unpot the original and get it rewound and repot it either using epoxy potting compound or the original bitumen. Its a lot of aggravation and to be avoided if possible. I have a small electric oven I use for B15 transformers after an incident with the kitchen cooker led to some domestic disharmony a few years back.Logic is an organized way of going wrong with confidence
Originally posted by nevetslab View Post
I've never unwound any xfmrs to find the fault(s) and try to re-wind them. Life is too short to move into that area.
I'd never heard that comment before...B15's commonly 'eat' power xfmrs. I can't imagine Ampeg would have designed the xfmr for 60Hz operation only (as an oversight). Running a design like that on 50Hz Mains WOULD tend to do as commented on.
a) The change from 60 to 50Hz - I'm in the UK so 50 is what we have. Although I see plenty of US imports with transformers that have been replaced.
b) Modern 6L6s bias hotter than old ones - these amps are either cathode bias or fixed bias with no bias adjustment.
c) Modern GZ34/5AR4s have less voltage drop than old ones
d) I measured the voltage from my alleged 240/110 step down transformer - its 125V
Some or all of these factors occurring together will overheat the transformer to the point of insulation failure. A short in the rectifier tube is another regular cause.
Like all the best disasters its a multi-factored failure.
Originally posted by nevetslab View PostB15's commonly 'eat' power xfmrs.
Time was, you'd have to pay $300+ and shipping besides for a replacement. Looked at Fliptops, now they have theirs made by Heyboer and only (!) $225 + shipping. In spite of the price reduction, I did it the way I have for decades now. Melt out the original PT (or OT if that's what's needed), clean the can, repaint it, stuff it with a PT intended for Fender Vibrolux plus a mix of beeswax and paraffin wax like what's used for pickup dipping. Haven't had one melt the potting wax yet, and I have that repaired B15 warming up in my living room right now, to prove it once again.
Bias? If it's running too hot or too cold, we know what to do about that. Right?
With the Vlux PT, the B15 in my LR is running about 460V B+, delivers 33W @ clip to 8 ohms. Healthy statistics, and the good ol' fashioned tone is right there where it belongs.
- Likes 1
.., stuff it with a PT intended for Fender Vibrolux plus a mix of beeswax and paraffin wax like what's used for pickup dipping.
Paraffin melts around 65°C, beeswax around 70°C. Internal winding wire temperature can get much higher than that, sometimes approaching 100°C, even higher in fault condition.
And wax/paraffin vapour is highly flammable.
A suitable potting material could be bitumen (tar, asphalt), but surely no fun to work with.- Own Opinions Only -
- Likes 1
