Hey everyone. I've got a 1989 Laney AOR 50 Series II head (schematic: https://www.thetubestore.com/lib/the...-Schematic.pdf) that has an interesting issue going on in the FX loop.
Another somewhat interesting observation is that, if I turn all the knobs on the amp to 0, and plug a signal into the Line Out, instead of the Return, the hum is still there, but it's quieter.
Some background
Overall shot of the amp's PCB
Close up of the section of the board containing IC3 (TL072CP dual op amp IC used for the effects loop buffering)
I'll be getting some TL072CPs in the next week or so, so I'll replace the IC, but it's sort of a last ditch effort.
Anyone else have any ideas?
Thanks in advance
- The amp sounds completely fine with nothing in the loop
- The amp sounds completely fine with just a cable between the send and return jack
- The amp sounds completely fine with a 9V battery powered true bypass pedal in the loop, but only when the pedal is off
- True bypass pedal in the loop, turned on
- Buffered pedal in the loop, regardless of whether it's turned on or off
- Either of the above plugged directly into the loop return, e.g. guitar -> pedal -> return, with nothing plugged into the amp's inputs
- A guitar plugged directly into the loop return, with nothing in the amp's inputs
- The interesting part here is that I get the hum at full volume with the guitar volume on 0, but as I raise the guitar volume, the hum gets quieter, almost completely disappearing with the guitar volume ~50% up. Past that, the hum gets louder until the pot is at 10
Some background
- I've had the amp for about 10 years. I don't think I've ever used the effects loop
- I replaced every electrolytic cap in the amp around Oct 2015 (overly paranoid, but hey, the amp sounded a hell of a lot better afterwards)
- I just replaced the Send, Return, and Line Out jacks yesterday with brand new Cliff UK jacks to rule those out (it didn't change anything)
- Inserting a cable into the loop return, I measure 100 kOhm DC resistance between tip and sleeve
Thanks in advance
