The schematic only shows the power supply for the IC on IC3B for some reason
FX Loop Buffer Circuit Hum (Not a Ground Loop) (1989 Laney AOR 50 Series II)
Hum is still present with a shorted plug inserted
I suspect 60Hz ripple on the -30V supply. Check all related filter ecaps.Last edited by Helmholtz; 11-24-2020, 12:57 PM.- Own Opinions Only -
If hum is present when a link cable is used, it must be present when no link cable is used or do you mean just one plug inserted to break the link if so which socket are you plugging into.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by Helmholtz View Post...I suspect 60Hz ripple on the -30V supply. Check all related filter ecaps.
My money is on C28 or associated solder joints. Hum on that node would precisely explain with the variation in hum you get with the guitar volume. When the source impedance is about 25K the hum will null due to the differential input action of the opamp.IC3BLast edited by nickb; 11-24-2020, 06:56 PM.Experience is something you get, just after you really needed it.
- Likes 4
So, whenever I do get a chance to open this up and run it, I'll turn on the knobs on the front of the amp to 0, insert the shorting plug into the return jack, and check:- VDC and VAC between ground and pin 8 of IC3 (should be -30 VDC and 0 VAC, if AC present, likely that filter cap(s) C34 and/or C35 are bad). This should cover Helmholtz and pdf64 's suspicion of ripple on the -30 VDC supply
- VAC between ground and the right side of R43 (should be 0 VAC, if AC present, likely that filter cap C28 is bad). This should cover nickb 's concern about C28 (I've got a good feeling about this one, since it's the only one that lines up with the weird behavior with the guitar volume pot)
I seems that the output impedance of the send stage of around 1k provides good hum cancelling.
All electrolytics were replaced 5 years ago. I don’t have an ESR meter, but I can certainly measure DC resistance to test them for dead shorts
But check if the ecaps (especially C28) in the -30V / - 15V supply are wired with correct polarity, meaning positive end towards ground.Last edited by Helmholtz; 11-24-2020, 11:14 PM.- Own Opinions Only -
- Likes 1
Originally posted by Helmholtz View PostBut check if the ecaps (especially C28) in the -30V / - 15V supply are wired with correct polarity, meaning positive end towards ground.
Originally posted by neptoess View Post
No hum when I actually jumper send to return. The hum is present when I simply insert a shorted plug into the return jack though.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 1
If you measured with your DVM, you may well have been mislead by an inaccurate reading. DVMs are notoriously bad at low value AC. The inductance in the leads will give a few millivolts on their own just by shorting the probes together.
What have you got on your oscilloscope?
There will need to be more than that sort of ripple on the recovery amplifier as it only has a gain of around 4 even if there was 5mV of ripple, that equates to just about audible against the noisy valves.
I would go back to basics and start a fresh with the diagnosis.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
