Upon powering up cold, the standby light comes on but is a little noisy, then after 30 seconds warmup, the noise disappears for good.. then when I turn the tremolo on, the standby blinks in time with the trem...is this normal for this amp and if not, what's the most likely problem?
Vox AC 30 Standby LIght Blinks with Tremolo
There are so many different AC30 versions that have been built. Please post the exact schematic for this particular unit.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Sorry about that, it's the CC2x. I've seen several posts regarding problems with the standby blowing rectifier tubes. Vox resolved this by adding a 5W resistor to the standby switch. If this unit doesnt have one, I can add it but how many ohms should I use & would it just be soldered across the leads of the standby switch?Attached Files
I think it is not necessary. Simply turn the amplifier on and off with the power switch only.
As for the flickering of the pilot lamp when activating the tremolo, I have seen it sometimes. It´s very likely to be accompanied by a hum noise on every oscilation. In my case it came from a serious imbalance in the power tubes.
- Likes 1
Poor matching was what Pedro meant when he said imbalanced tubes in this model can cause the issue you are having. So a matched pair may cure the issue. It's worth a try, if it doesn't help you can keep them for something else.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
It would be appropriate if it were possible to previously measure the current flowing through each tube. I always do it. Normally I use tube socket adapted to measure the plate current with an ammeter. It can also be measured through the cathode.
If you find very different values you can distribute them as symmetrically as possible between both sides (1/2 and 3/4) trying to make both sides form a similar sum. For example, if you find values of 45, 48, 30, and 36 mA, you can distribute them as 45 and 36 mA on one side (1/2) and 48/30 on the other (3/4). This often helps reduce flicker and associated hum while achieving a rounder sound.
These tests are also used to determine if any tube is inactive, which could create a similar effect due to the imbalance it would create.
If you cannot do these previous measurements and you are going to buy a quartet, it is better that it is matched.
Excuse my poor English.
- Likes 1
Originally posted by Perkinsman View PostSorry about that, it's the CC2x. I've seen several posts regarding problems with the standby blowing rectifier tubes. Vox resolved this by adding a 5W resistor to the standby switch. If this unit doesnt have one, I can add it but how many ohms should I use & would it just be soldered across the leads of the standby switch?
