I recently bought a few project amps locally, one is a Music Man Rd 112 One Hundred. According to the guy his tech said that it was almost working but then the tech passed away unexpectedly. I opened up the amp and was terrifed by the wiring I saw. I think they were trying to convert it into a full tube amp by adding two preamp tubes and bypassing the solid state preamp. I just started cutting and removing everything attached to the tubes because it was scary.
The scariest amp I have seen
Originally posted by glebert View Post
I certainly didn't power it up to check, but I don't think they implemented the voltage doubler, so probably only 400V or soThis isn't the future I signed up for.
Originally posted by Leo_Gnardo View Post
I scanned around for a schematic but didn't see any. If it's anything like RD50's I worked on, their B+ was around 650-675V similar to most other MM's. Bad enough to get stung with 400V. Beyond that, if you survive the hit you'll turn the air blue, cussin' like a sailor. Works for me. Ding dangalang BLANGGIT!
Oh, and I did check the PT on a variac and LBL to make sure the voltages are right and no shorts or opens.Last edited by glebert; 12-22-2020, 12:36 AM.
