hello everyone I would like to ask the opinion of you fans on a guitar amp a marshall TSL60, I have an unstable bias problem, practically if I set it to hot at 38mv after a while it starts to rise or fall with a variation of 6-8mv at volume 0, I replaced the resistors R12-R13-R24-R25-R76-R2, C12, C69 the 22k bias potentiometer and the Zener diode ZD3 all that concerned the bias regulation circuit. But nothing seems to have changed actually all the replacement parts I measured with the tester and they gave the same measurements as the new parts. The thing if I then start playing at medium-low volume oscillates 39mv 42mv, if instead I start playing at medium-high volume the mvs rise until the tester no longer scores you can see that it goes from 39 to 50 80 120mv up to 200mv, then the tester goes off the scale and doesn't score anymore and although with the guitar I'm far from the amp when it's about to end the sustain effect starts whistling which is an impressive thing, as I stop the strings it stops whistling and the tester starts to score again and returns to 38mv but it is never stable. Attention the oscillations occur only when I start playing the guitar repeatedly, even if you leave the volume of the amp at full throttle and the guitar volume at zero there is no oscillation it remains at 38mv and then oscillates of those 6-8mv. I can't figure out what triggers this problem as long as it is. I am an enthusiast but also a beginner in electronics so have pity, I am also trying to understand what correlation there is in raising the G3 grid value with the guitar signal input in the sense why as soon as I start playing with medium-high volume G3 rises, shouldn't it stay on about 38mv? While with medium-low volume all this does not show up except with very slight fluctuations. Thank you very much
