Trying to get this amp right. Volume and tone act weird. Seems like the Bass and Treble pots have a big effect on the Volume pot. Or they all seem to counter-act each other.
Both channels have similar behavior. I will describe the Normal channel.
Volume at zero does not cut the volume. Signal is loud at zero and Volume pot behavior does not kick in until about the "4" indicator and above. Treble does not kick in until volume pot is at 4 or higher. Below 4 the tone is muffled and bass like regardless of treble pot setting. Once volume is at 4 and above the treble pot is responsive.
I have stepped through the wiring from input to output of V3. All seems good.
Both channels are behaving similar. Wondering if the pots need to be replaced. I did check the Bass channel volume pot with wires disconnected and it did behave properly on the meter.
Schematic that I am using is attached.
Thank you for any suggestions. MC
Fender-Bassman-50-Schematic.pdf
Normal channel V3 is in the top center of below pic.
Normal channel pots below
