Where can I buy these reverb tank foot grommets? (I think that is what they are called.) They go inside the reverb tank rubber mounting foot and they have a mounting screw poke through them. The purpose is so you can fasten the tank to the inside of the cabinet and without squishing the rubber mounting shock absorber.
Reverb tank foot grommet
They space the screw so it doesn't trap the rubber too hard as that will reduce the suspension.
I have used a washer and care when tightening the wood screw.
This is why ...; https://uk.rs-online.com/web/p/products/7689978/?tpr=2
or https://uk.rs-online.com/web/p/rivets/2067822/
No idea what to do with the rest.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
It is an eyelet, like they use on Fender part boards, just a l;arger size. The grommet is the rubber ring.
But you can survive without it. Just turn the screw down far enough to be secure, just not so far as to crush the rubber.
Or find some tubing to fit the hole and cut off a piece of it and insert. Under the screw, it won't go anywhereEducation is what you're left with after you have forgotten what you have learned.
- Likes 1
Crikeys, if I have one, I have a hundred. Plus the newer-style silicone "shock absorber" inserts. Replacement tanks usually come with them installed, though in most cases they're not needed. For instance when the tank is inside a "sock" as in many Fender amps. And you know me, can't throw anything away, so a drawer in one of my parts bins is chock full of 'em.This isn't the future I signed up for.
Originally posted by Enzo View Post......you can survive without it. Just turn the screw down far enough to be secure, just not so far as to crush the rubber......
