Hi All
Hope we are all good
Well this is doing my head in. I local recording studio bought this used
It is clear to me that this amp has had this fault and an a repairs have been made to sort
When it arrived i can see all new JJ tubes about 2-3 months earlier. When you turn the volumes down its quite
but when you turn up the normally channel you get a noise ( to me it sounds like a ground issue is it 60Hz.
picture below 50mv 1ms on the anodes of PI
when you turn all the volumes down its quite with a slight background noise.
when you turn the normal up to about NO 2 is quite then the noise gets louder from about NO 4 until the max where is way to much and un usable
the other channels are better but not perfect
all of the vol pots have been changed prior to me using the Solder tag alpha types with short connection wires
removed the PI tube all quite, you can filter some of the noise out with tone cut and other controls
this amp has from stock all of the grounds going back to the same point, By the Power tx
This amp does show signs of someone trying to fix this same fault ( Maybe)
AC3093PA-Reissue.pdf
this is what ive done
1. Checked and changed all the tubes for new inc GZ34
2. Made the ac heater wires a little tighter twists
3. Removed the CT for heater and checked with 2x 100R to ground
4. all of the filter caps changed 10uf caps now 22uf and the 33uf caps now 47uf
5. R1 47k on PI lifted and grounded elsewhere
6. Tact on extra caps for the filter stage still the same
7. all input jack sockets are good
its doing my head in , but the only job i got to do really as the UK are in lockdown
This is way too much noise, I have another Dallas arbitter version in workshop waiting collection which is so quite in comparison
Any help would be grateful
