G1: I ran a signal from my pc speakers to the Amp speaker to make sure that even though the specs tested correct, it would actually make noise. You know, cone not detached,etc.
Dave H:Cathode resistor tests 508 ohm, good.
No, all my probes are at x1. With no signal going, pin 3 and pin 5 on 6v6 have negligable voltage difference, with signal of 1000Hz 460 mv pk-pk, volume knob at 4 only 4x, volume knob at 10 only 1.2x.
Helmholtz: Changed cathode cap, probe 10:1 signal 1000Hz 460mv pk-pk. Not a pretty sine wave at volume 4, pointy at the positive peaks. Max 5.52V Minimum -8.87V lightly undulating.
Sound still outputs as tinny and far away.
Is there any chance that using the headphone out on my p.c. speakers could be part of the problem?
