I'm working on a Peavey Bass 300 from the early 70s. It seems stable when turned on and no load is connected - on a bulb limiter, I've got a stable dim glow that doesn't change. However, when I plug in a speaker, I get nasty loud popping that corresponds to the amp's "on" light dimming. When turned on and connected to a bulb limiter, the bulb glows brightly as the speaker pops, dims in between pops. Unplug the speaker, bulb stays dim again. Same effect if I connect a dummy load instead of a speaker (just can't hear the pops).
All the power transistors check fine out of circuit, and I've replaced the mica insulators and grease. I know the electrolytics are all way past their lifespan and will be replaced at some point. I'm curious where I should start looking to diagnose this and would love any thoughts and ideas - thanks!
Matt
Matt
