Thanks. I'll do it ASAP.
Problem with Dr Tube Bias mod repair for Marshall DSL100
How do you measure idle currents?
10V drop across OT primaries seems rather high.
Measure DCRs of both halves of the OT primary. Make sure filter caps are discharged and short the speaker output while measuring.- Own Opinions Only -
Originally posted by greengriff View PostI could actually get to the legs of R71. Voltage was 465 on one side of it, and 475 on the other. Screen voltages: V5=456, V6=458, V7=457, V8=459. Today the anode voltage was 464.Last edited by nickb; 02-03-2021, 10:38 PM.Experience is something you get, just after you really needed it.
- Likes 1
Originally posted by nickb View Post
That seems very reasonable to me. That's a very different from the number for the screen voltage that was reported earlier.
That seems very reasonable to me. That's a very different from the number for the screen voltage that was reported earlier.Originally posted by greengriff View Post
Yes it was completely different! No idea why. Today the amp biases properly within range as well. I have no clue as to what's changed!!!!
Restoring the screen voltage allowed normal idle current. I would think there may be a poor solder connection at R71, and the fault may return.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Originally posted by greengriff View PostThank you. When I have time I'll dismantle the amp and remake the connection just in case. Shall I still measure the DCR of the OT as suggested by Helmholtz?Then do the math to solve for idle current and see how close it agrees with the number from the bias test points. It will be good exercise to familiarize yourself with the technique. Then you can use it in other amps that don't have the cathode resistor test points.
- Likes 3
