I have a Behringer power amp board with a burnt and smelly inductor... Since it is stereo you can also see an undamaged one on the picture below.
The inductor burnt out becuase a cap was short, so although the amp works OK, I doubt it will ever be reliable as it looks like there will be shorted turns. Since I am a bit bored, I thought I would replace the inductor which according the schem is 21uH but I have no idea what power rating.
My options seem to be:
Use a 22uH inductor - possibly removing a couple of turns, if critical - but since I don't know the power rating do I just go the closest size is there a better way to estimate the power rating?
Could I rewind the inductor, what kind of wire would I be looking to buy? How could I test its inductance
L1 21uH
Wire outer diameter is 1.36mm / 0.053"
~44 turns on a 36mm OD core.
![DSC_0011.JPG Behringer Burnt Out Inductor](filedata/fetch?id=924353&d=1612714155)
L1 21uH
