Sorry if I am repeating myself, I have been away from my shop with illness. I installed a Dr. Tube stable bias mod in a Dual Super lead 100. It was suscessful, but I couldn't get the tubes to bias less than 19 watts, which I thought was too high. I adjusted a resistor, and got it to adjust into range, but then found a Marshall adjustment bulletin in a couple of Marshal forums that call for clipping on the 3 pin connector at the back, and putting each side at 90mV. With a B+ of 475, that's 21 watts, if I am not mistaken. Thinking something wasn't quite right, I went to the bias probe method, this time measuring 37.5mA, which was better but still high in my estimation.
What is going on here, and where should I bias this thing, givien these amps tendency to burn up?
