The Magnatone 450 guitar amp seems not particular loud so I’m checking the power tubes bias.
The plate voltages and B+ are considerably lower than the schematic states. (See schematic attached)
For plate voltage I'm getting 340v and the schematic says 410v. I tested the plate current and I'm getting around 7mA. Seems very low.
I’m adjusting the 15k resistor (circled in green on the schematic)
Here’s the results of gradually increasing that resistor and lowering the neg voltage going to the grids.
Resistor | Voltage going to grid | Plate current | Plate voltage
15k -23v 7mA 355v
27k -18v 13mA 325v
37k -14.7v 16mA 313v
54k -11v 21mA 300v
81k -8.6v 24mA 290v
Should I change that 68k resistor going to ground? So these two resistors are like a ratio and affect each other. I should probably go back to lowering the first resistor (green circled one) and then lowering the one to ground too.
I’m trying to get the bias to be something close to the middle (according to the 6973 data sheet)
Plate Voltage 350v
Plate current 44mA
Control Grid -22v
But the more I higher the Plate current, the lower the Plate voltage goes.
Am I going about this the right way?
Thanks for any help!
