Finally back to Back-Line gear maintenance. Going thru the GK bass heads from our NY Inventory, and found a GK 550 Fusion which, when first powering it up, output connected 4-wire to a GK 410 Bass Cabinet, I heard low-level hum while the Red light around the power switch is lit, then changing to Blue light, I heard a substantial thump thru the speaker, amp in Standby mode (Blue light flashing). I unplugged the speaker cable from the amp, and plugged my Fluke 8060A DMM into the 1/4" speaker jack. With the amp off, I was reading -0.67VDC. Interesting. Switching the amp on, that changed to -6.7VDC while the Red lamp is on, then while switching to Blue light, I briefly saw the output read -74VDC before immediately going down to nominal 0V (around 12mV offset with the amp on.) I repeated this several times. Each time, during the start-up powering, reading -6.7VDC, a quick pulse to -74VDC, then down to 0V. I fetched my adapter cable to allow reading both Woofer and Tweeter, and checked to see if there was anything similar occurring on the Tweeter amp output. 0V during power-up, 0V during powered on, but a brief -3 to -4VDC pulse during power-off, which immediately dropped to 0V. No load (10M) when just connected to the DMM.
I can't say I've seen this behavior before on any GK1001RB's or GK550 Fusions. The GK 550 Fusion uses the power amp PCB assembly from the GK 1001RB. I still haven't called GK to have them send me the service documents for the 550 Fusion amp. I've attached the power amp PCB Schematics for the GK1001RB for the time being.
1001RB-II_POWER_AMP_PN_206-0260.pdf
