Help me find this fuse holder
  • Help me find this fuse holder
    I looked all over, but I must be doing wrong or calling the wrong thing or something, because I have come up empty handed. I have contacted the manufacturer (Egnater), but have not heard back. It is for 20x5 mm fuses.It is pin thru mounted. The body is 27.5x 13 mm without the cap. The pins (one is broken off) are 10 mm apart, with the rear pin very nearly flush with the end edge. The body is round with a flat bottom. It is tricky because the cap has to be accessed thru a hole in the rear of the chassis.
    Thanks to anyone who may be able come up with this part, or have some insight on it.
ID:	926195 Click image for larger version
    https://www.digikey.com/en/products/...15-H-1/7717794
      They're also used on newer Orange amps, I bought some from one of the amp parts places.
        Can't see the backside of that broken one, but is it not possible to solder a piece of stiff wire to it and re-use the holder?
          Yes, Yes Yes!! That's exactly the right one! Thank you Dude! Actually, the plastic catch inside it is broken, which was the real problem. The pin came off while trying to get the stubborn SOB off the board.
          I love this place.
            Words are nice on the ears but to better show your appreciation:
