Well, I was determined to figure this one out on my own but I am completely stumped. I'm getting a hum from the reverb recovery stage of this Gibson GA-15 RVT and I've tried everything I can think of to correct it but to no avail.
The amp is pretty much quiet when C15/R15 is grounded, which is how the footswitch turns off the reverb effect. But when that point is ungrounded by pressing the footswitch or disconnecting the footswitch cable, there is a distinct hum present. If I disconnect the reverb tank the hum is still there but also with a lot of hissy, RF type noise. Because the reverb level pot is on the reverb driver side it has no bearing on the amount of hum. I've ruled out the V2 tube and coupling cap, in fact I went as far as wiring in another tube socket, and other things too numerous to mention, still I haven't been able to eliminate it. Suggestions?
Schematic:
GA-15RVT.pdf
Schematic:
GA-15RVT.pdf
