Bugera 333XL-212 Lead channel on Crunch channel
  • Bugera 333XL-212 Lead channel on Crunch channel
    My amp has developed schizophrenia. When I switch to the lead channel I can hardly hear anything unless I crank the volume to max. The eq controls do nothing.... However, the controls on the Crunch channel affect the lead channel. Volume, eq, gain. Any ideas on what may be causing this? Any info would be much appreciated.
    Are the leds responding correctly?
    Do the relays switch?
    Is the 5v supply to the digital board correct?
