It is out of a 135 watt UL Twin Reverb, 8 ohm, doesn't have the typical EIA code. It is damaged and I need to communicate to the re-cone shop what it is in order to get a price.
Anyone know what this speaker is?
Originally posted by Randall View PostI need to communicate to the re-cone shop what it is in order to get a price.
- Likes 1
Presumably both speakers are same age and suffered the same history. The other may be intact, but you might find if you poked the surround, you finger would go right through. meaning it might make sense to ressurround both.Education is what you're left with after you have forgotten what you have learned.
Yep, that photo looks just like a version the ones I have. Only these are inverted, the round silver piece with the flat edge is actually underneath the round black magnet on these, but the terminal board is the same. Fane it is. I have sent an inquiry with a photo to the re-coner, I'm waiting on his response. He has done some work for me before, and I think he is very good. I pulled the other speaker, and for what ever reason, it seems fine. A call today resulted in me being told, the surround on this type of speaker isn't really repairable with any type of reliability, that is only for foam hi-fi surrounds. My customer is already into me for $300 before the re-cone, so I seriously doubt he is going to want to do them both if one seems okay, despite this very advice from the shop. It came in for power socket replacements, and ended up being two dead sockets, two missing power tubes, four burned up power supply resistors, two bad filter caps, a shredded speaker, and a wrongly wired Mercury OT that I suspect was never needed. He is ornery, and upset at the hack who did the "work", his sound man, who left town owing people money. Plus, he thinks this UL Twin is the greatest sounding amp ever, so whatever that means. I just want to get him back on the road. If he blows another speaker down the road, It's not on me. I don't upcharge for what it costs me to send a speaker out for re-cone, because it's probably going to be around $125.It's weird, because it WAS working fine.....
Originally posted by Randall View PostIt is out of a 135 watt UL Twin Reverb, 8 ohm, doesn't have the typical EIA code. It is damaged and I need to communicate to the re-cone shop what it is in order to get a price.
1)
https://www.jensentone.com/builder-profiles/fender
https://www.jensentone.com/tone-chartIt's All Over Now
1) that is not an Eminence speaker and very very unlikely otīs a Jensen.
2) that is a "British" frame. Typical of Celestion but others have used it too.
In any case, very unlikely itīs a Celestion either.
3) Might be a Fane: frame shape and black finish match, also shape and size of terminals tagboard:
but not exactly a Medusa, Randallīs looks older and cheaper, it has no vented pole piece like this one:
Might be a simplified/cheaper version though, offered to Fender to meet some specific batch order at a price.
As of surround: cloth and foam surrounds are routinely replaced, but vthatīs Hi Fi world, at most PA or Bass.
Randall did NOT show the damage to be repaired (why doesnīt that surprise me?) and paper edges are not meant to be replaced (they are one and only with the rest of the cone, felted and pressed in the same single operation) but of course it can be done.
a) neatly cut around the speaker cone, separating intact cone from shredded/torn edge.
Clean speaker edge, after removing (presumed) cardboard gaskets.
b) cut the edge/surround from a perfectly good paper cone.
Re glue (use Elmerīs or similar white glue) this new edge both to original cone (overlap some 8-10mm) and speaker frame.
I suggest cutting original (not shown) dust cap to allow cone re-shimming so cone remains centered.
Next day reattach dustcap, may use dope to make repair less obvious.
The other speaker should be redoped to match.
No need to send it back and forth just for that, reconer might send Randall a small dope bottle so he does that himself.
4) the Fender speaker magnet is HUGE, larger even than the confirmed Medusa one.
I didn't show the damage to the speaker because I wasn't asking about the repair, I was asking about identification. I don't know what I have done to always seem to get on Juan's grumpy side, but here are photos of the damage, which I am not going to attempt to repair. I am not a re-cone shop, even though I have done it successfully on a number of occasions with the right supplies. It just isn't cost effective for me like it might be in other parts of the world. Plus, if my repair doesn't hold up for whatever reason, I'm on the hook, and that means wasted time and costs for me. It's just easier for me to quote a price, send them out, and install them when they return. I have a shop to run, and a reputation to uphold, so it just is what it is. And for the record, last year I saved a torn up 15" bass cab speaker that had a mic stand poked into it, with some paper towel and black nail polish that is still in service for far less than a replacement or a re-cone.
Having said that, here are the photos of the damaged speaker. It is completely separated from the rim. If you would try a repair if you were in my shoes, I applaud you, but sometimes it's not worth it for me, and this is one of those times.
Also, my speaker actually does have a vented pole piece. It was dust covered and the filter material disintegrated when I attempted to clean it.
Last edited by Randall; 04-03-2021, 02:04 AM.It's weird, because it WAS working fine.....
- Likes 1
Originally posted by Randall View PostI didn't show the damage to the speaker because I wasn't asking about the repair, I was asking about identification. I don't know what I have done to always seem to get on Juan's grumpy side,
That said, I *always* try to help you, by answering the Technical side
Specifically because edge replacement was suggested earlier, by others, and I cleared the idea, showing how it is different from a HiFi/PA/DJ speaker repair.
If I state something, in general I try to give the reason behind it and if possible, some practical solution.
Of course full reconing is the "easy" solution .... IF available that is.
Not sure how easy it is to get FANE spares in USA, and at what cost.
If they have to be ordered from England ...........
As a side note: you only asked for identifiction, true.
I answered that, AND diagnosed the problem AND suggested a solution.
But as they say, no good deed goes unpunished
- Likes 2
