At this point, just to clarify where we are, am I correct that we have basically established that the amp does not blow fuses until the tubes are installed?
Also, crappy filter caps can drop bias voltage severely, it generally results in low bias, not completely absent bias. meaning even after replacing the filter caps, you may have an open rectifier diode or a resistor, or just a broken connection.
