V5,6,7,8-pin#8(0.00mv)
70s Ampeg V4B Blows Fuses
Originally posted by ca7922303 View PostNo components appear burnt.
The new batteries in the measuring instruments are a miracle.
They broaden the horizons.It's All Over Now
Be more specific in describing the symptoms.
You are very stingy on words.
For V5 you asked a question, got an answer, what is the problem now.
About V5
#123It's All Over Now
One of the supply voltage dropping resistors may have opened up or have a bad solder connection.
These would be the voltages on either side of resistors R51,52,53, & 55.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Originally posted by ca7922303 View PostR51(2.2k), R52(OL), R53(OL), R55(0.46K) resistance. R51(570v/570v),R52(-4mv/570v), R53(585v/5mv), R54(585v/585v). When I replace R52 & R53 are they 2 watt resistors?
When measuring the voltage, in which position is SW4
It's All Over Now
SW4 is the standby switch. It needs to be in 'play' position for all the testing. R52 and R53 are possibly mounted on the big capacitor cans. I'm not sure if you have your meter on the trace side of the board? You may have to dig in more with your meter to get the reading. Please re-check.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
