This one measures 0.5v/311v.
70s Ampeg V4B Blows Fuses
Originally posted by ca7922303 View PostThis resistor measures 620v/311v.
The voltages you measured (620v / 311v) are OK because the resistors are connected in series.
Compare the detail that you show with the schematic, and it will be immediately clear what is about.
For R52, R53 (4.7k / 2W) use schematic and find them.
It's All Over Now
- Likes 1
Originally posted by ca7922303 View PostNot sure what you mean? Can you explain further?
Checking how the power amp works.
Follow the schematic.
Connect speaker to J6 SPKR
StandBy (SW4) in position ON
Measure and upload the voltage measurement results at points 1, 2, 3, 4
Remove V201 (6K11) to turn off the preamp.
Plug the guitar into jack J4 or J5.
If the output stage is correct you should get a clean guitar sound of the order of 10-15W
Descriptions of how the V4B responds.
It's All Over Now
Originally posted by g1 View PostDo you have the resistors like in the bottom right of this pic?
Don't see how they could get causing the issue and they seem to be connected to impedance switch. Can you explain how they are connected to R52,53 on board? Thanks for your help.
