Originally posted by g1
View Post
70s Ampeg V4B Blows Fuses
Try it with one probe on each side of the diode, black probe to cathode end (silver band).Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
It's just D5 I was wondering about, and I think that is normal but I'll double check mine tomorrow.
How many of the tube heaters are not lit up? They can be hard to see sometimes so checking in the dark can help, also feel them for any heat.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostIt's just D5 I was wondering about, and I think that is normal but I'll double check mine tomorrow.
Originally posted by ca7922303 View PostOnly one(1) tube socket is not producing a lighted or warm tube. This socket has been tested with several known good tubes.
On the same tube socket check if there is soot between pin 2 and pin 3.
If the tube socket damaged, burned replace with a new socket.
https://drtube.com/datasheets/7027a-rca1959.pdf
It's All Over Now
- Likes 1
After you get that socket working, try this test again to see if power amp & supply are still basically working: https://music-electronics-forum.com/...556#post929556Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by vintagekiki View PostOn a tube socket that is not producing a lighted or warm tube, check between pin 2 and pin 7 that there is a voltage of 6.3 VAC.
Originally posted by g1 View PostAfter you get that socket working, try this test again to see if power amp & supply are still basically working: https://music-electronics-forum.com/...556#post929556
